configure ports dwdm channel
configure port all | port_list dwdm channel channel_number
Description
Selects the DWDM channel frequency for the selected ports.
Syntax Description
all
Specifies all ports.
port_list
Specifies one or more ports or slots and ports.
channel_number
Specifies the channel number, which corresponds to one of 102 available channel frequencies.
Default
Channel number – 21.
Usage Guidelines
The following table lists the available frequencies and the channel number you must specify to select each frequency.
Table 1. TX Wavelengths and Channel Assignments for the Tunable DWDM XFP/SPF+
TX Wavelength Channel TX Wavelength Channel TX Wavelength Channel TX Wavelength Channel
1568.77 nm
11
1558.17 nm
24
1547.72 nm
37
1537.40 nm
50
1568.36 nm
1150
1557.77 nm
2450
1547.32 nm
3750
1537.00 nm
5050
1567.95 nm
12
1557.36 nm
25
1546.92 nm
38
1536.61 nm
51
1567.54 nm
1250
1556.96 nm
2550
1546.52 nm
3850
1536.22 nm
5150
1567.13 nm
13
1556.55 nm
26
1546.12 nm
39
1535.82 nm
52
1566.72 nm
1350
1556.15 nm
2650
1545.72 nm
3950
1535.43 nm
5250
1566.31 nm
14
1555.75 nm
27
1545.32 nm
40
1535.04 nm
53
1565.90 nm
1450
1555.34 nm
2750
1544.92 nm
4050
1534.64 nm
5350
1565.50 nm
15
1554.94 nm
28
1544.53 nm
41
1534.25 nm
54
1565.09 nm
1550
1554.54 nm
2850
1544.13 nm
4150
1533.86 nm
5450
1564.68 nm
16
1554.13 nm
29
1543.73 nm
42
1533.47 nm
55
1564.27 nm
1650
1553.73 nm
2950
1543.33 nm
4250
1533.07 nm
5550
1563.86 nm
17
1553.33 nm
30
1542.94 nm
43
1532.68 nm
56
1563.45 nm
1750
1552.93 nm
3050
1542.54 nm
4350
1532.29 nm
5650
1563.05 nm
18
1552.52 nm
31
1542.14 nm
44
1531.90 nm
57
1562.64 nm
1850
1552.12 nm
3150
1541.75 nm
4450
1531.51 nm
5750
1562.23 nm
19
1551.72 nm
32
1541.35 nm
45
1531.12 nm
58
1561.83 nm
1950
1551.32 nm
3250
1540.95 nm
4550
1530.72 nm
5850
1561.42 nm
20
1550.92 nm
33
1540.56 nm
46
1530.33 nm
59
1561.01 nm
2050
1550.52 nm
3350
1540.16 nm
4650
1529.94 nm
5950
1560.61 nm
21
1550.12 nm
34
1539.77 nm
47
1529.55 nm
60
1560.20 nm
2150
1549.72 nm
3450
1539.37 nm
4750
1529.16 nm
6050
1559.79 nm
22
1549.32 nm
35
1538.98 nm
48
1528.77 nm
61
1559.39 nm
2250
1548.91 nm
3550
1538.58 nm
4850
1528.38 nm
6150
1558.98 nm
23
1548.51 nm
36
1538.19 nm
49
1558.58 nm
2350
1548.11 nm
3650
1537.79 nm
4950
The supported channel numbers are not contiguous. If you specify a channel number that is not listed in the preceding table, the following error message appears:
Error: DWDM Channel configuration failed. Channel number 100 is out of configurable range. The channel range for the Optical module in port <port number> is 11 .. 6150.
If the optical module in one of the ports in the specified list does not support DWDM, the following error message is displayed:
Error: No TDWDM Optics on port <port number>.
If the optical module in one of the ports in the specified port list is not an Extreme supported optical module, the following error message is displayed:
Error: DWDM Channel configuration failed. Optical module is not Extreme Networks certified. For DWDM channel configuration, Extreme Network Certified DWDM module is required.
To display the configuration, use the show ports configuration or the show ports information detail command.
The following command configures DWDM channel 21 on a modular port 1:1:
configure port 1:1 dwdm channel 21
This command was first available in ExtremeXOS 12.5.
Platform Availability
